跳转到主内容
型号A1318,闪存容量:32及64GB
299 个问题 查看全部
My screen is blinking after battery repalcement
Very abused ipod touch 3rd generation here.
It had taken a bath and had front display replaced by a professional repair shop. Then it stopped working months ago. Honestly, can't even recall why now.
Decided to try battery replacement as I thought the earlier bath had caused issues.
In removing front glass, it cracked.
Finally found a solder gun. In removing battery cable, the middle pad seemed to have a paper thin contact or small piece of metal (gold?) come up off the board. I tried to solder it back on but I'm not sure it worked. The rest of soldering looked really ugly and bumpy compared to the pretty pictures here.
Solder would bunch up in spheres bigger than solder pads. And, it did not want to flow through small holes in the battery cable. Are there different types of solder for electronics?
Anyway, I reattached screen and plugged in. Screen gets juice!
But, it simply flashes the apple logo over and over.
What does that mean? Dead logic board?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Sunshine, you could try this Holding the home button and the sleep/wake button at the same time while the ipod is plugged in then as soon as it starts to show the apple sign again hold the home button only. Or you can try try this. Let us know how you are progressing with your ipod Good Luck.
这个答案有帮助吗?
得分 1
添加一条评论
when its off, hold down home button then plug into iTunes (while still holding down the home button) and restore.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sunshine 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 1,807
