跳转到主内容
加入维修社区 - 创建账户
美国的电气安装是指按照国家电气法规 (NEC) 和当地建筑法规的要求,在建筑物和构筑物中安装电气系统的过程。
Replacement Timer for Intermatic Landscape Light Transformer
Would like to repair this unit rather than replace it. The timer mechanism has worn out and will not turn on the transformer when the tripper reaches the set time. It stalls at the set time and apparently slips when the tripper engages the switch. The part tag shows the timer as Intermatic PB115M2 but internet search shows no results. Any ideas? Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
As a followup to this issue. I was unable to find the timer mechanism but was able to replace the light sensors in my two boxes. The light sensors are still manufactured by Intermatic (Intermatic K4021C 120-Volt Fixed Position Thermal Photocontrol) and the system now works fine as a dark to daylight controller. Not completely fixed.... but functional and not in the Landfill.
由完成的
I have the same problem too. I dont want to spend another $200 for new transformer just because of the timer..
由完成的
I have the same problem too. don't spend extra for new transformer just because of the timer..
由完成的
添加一条评论
3个答案
已选择的解决方案
Hi,
If it plugs into a power outlet and you can leave it set permanently to ON then the easiest way to continue to use it, as finding the correct replacement timing mechanism may be difficult, is to connect it via a timer to the power outlet. (The timer is just an example, you may find a cheaper one that suits you better).
这个答案有帮助吗?
得分 3
4条评论:
Jayeff, Good idea!,
I have to find a way to protect an additional timer from the elements as the original plugs into a weather protected outlet.
由完成的
Hi Steve,
More expensive but here - https://www.bunnings.com.au/hpm-24-hour-... again just an example as you are 120V and this is 240V but the idea is the same
由完成的
Timer conected to timer? Lol
由完成的
I am new here. I found this thread when I was searching for a solution of a light transformer related problem.
由完成的
添加一条评论
ML121RT, timer quit working. Tried to find replacement timer. Could not find the exact timer. I found ordered and installed a WG2030 timer motor from Ebay. It’s working and keeping time. $23 Free Shipping.
这个答案有帮助吗?
得分 0
添加一条评论
Replacing the timer might be the best bet. While we couldn't find that specific part, HPM makes high-quality timers: Total Tools HPM. Check their selection to see if a compatible option is available.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Steve Mattson 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 63
总计 9,880
