跳转到主内容
Xbox One X (机型型号 1787)是微软推出的高性能游戏主机,替代 Xbox One S 。这款主机发布于2017年11月7日。
Why is my Xbox One X fan over spinning?
So I got my Xbox One X yesterday. After I unboxed it and set it up, it was working good. I powered it off after about an hour of use, and this morning I powered it on, to hear what sounded exactly like a Jet engine. I was confused because I live in the middle of no where, and realized it was my Xbox fan. I quickly shut it down and unplugged it. I decided to return it to the store as a faulty product but they told me they could not give me my money back, and there was not a technical warranty on it. So now my option is to open it, and see about maybe replacing the fan? I have heard of other faulty units like mine, but there is nothing I can do to return it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
4个答案
已选择的解决方案
Just because the fan is spinning up doesn't mean it's overheating. Anytime the console is doing something that takes a lot of computing power (large games, some updates, etc.) it will get warmer and that will sometimes cause the fan to spin up.
That all being said just contact Sony. As long as you have your store receipt they will usually take it. Also, I would never buy new electronics from a store that won't give you a warranty on them.
Hope this helps.
这个答案有帮助吗?
得分 1
2条评论:
It isn't overheating. The fan on console startup sounds like a jet engine. It is super loud and the console does not play games well, it acts as if the GPU is overheating or lagging. Terrible console. I'm going to a PS4 Pro.
完成的
Alright, so I've had my console for over a year and this wasn't really a problem until now. Up until now it has been moderately quiet. Now, this is happening to me. I also thought that it could have been the fan, so I cleaned out the fans with some compressed air. The problem wasn't fixed. Now, I opened up the console to see that the thermal paste is dry... like, super dry. I'm replacing the thermal paste in hopes that it solves my problem.
完成的
添加一条评论
最有帮助的答案
if its 6 days old your protected under consumer rights. your 30 days are not up yet.
这个答案有帮助吗?
得分 3
2条评论:
That is what I believed too. But Walmart said there is no returns, or warranty. Microsoft told me the same thing.
完成的
Bring up consumer rights. https://www.hg.org/consume.html they have to give you a replacement under law (if you threaten them with consumer rights they will "make a special exception" for you.)
完成的
添加一条评论
You could have alot of dust near your concole, or you enabled something that doesnt turn it off all the way which it gets warmer because its still running and not off all the way.
这个答案有帮助吗?
得分 0
添加一条评论
The xbox worked fine in the beginning so maybe its ur outlet or electricity in ur house? I would sell all the electricity what you got andmaybe move into someother country a quallity country for electricity if you want to be sure sell everything because maybe all ur electronics are damaged and if you move into a new house maybe the damaged stuff can damage again something in ur house what damage the next stuff maybe you wont see it but it is damaged and you dont even not know it
这个答案有帮助吗?
得分 -1
1条评论:
Tweeker. Need to lay off that Oklahoma Slim-Fast there buddy.
完成的
添加一条评论
添加你的答案
Alec 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 55
总计 12,264
