The laser pointer stopped working
My infrared non contact thermometer laser pointer stopped working.
What type should the replacement diode for the laser be?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
13条评论:
Hi @mtak12345 ,
Have you checked the power supply for the pointer?
What else have you checked?
Why do you think that the diode is the problem?
由完成的
I am just guessing..as it was working 3 weeks ago.....and suddenly gone off.....
I can take the head off and check if there is any voltage there?
由完成的
Hi @mtak12345 ,
What is the make and model number of the pointer?
由完成的
The supplier says ...Thanks for you information ,the Laser Diode type you want to replace is 6*12 .
由完成的
Hi @mtak12345 ,
You misunderstood me.
I wanted to know the name and model number of your "infrared non contact thermometer laser pointer" NOT the type of diode.
You never said whether you had checked the pointer's power supply or said what type of power supply it had, i.e. whether it had removable batteries or non removable rechargeable batteries etc. I could have looked up the User Guide to find out and possibly could've helped you further
The first thing that you need to check if an electronic device doesn't work is the power supply. Without power, nothing works.
由完成的
显示更多的8条评论
添加一条评论
