跳转到主内容
初代iPhone(又称iPhone 2G)。型号为 A1203,存储容量有4GB、8GB、16GB可选,机身颜色仅有黑色搭配金属铝。维修初代iPhone是容易的,需要耐心,一些工具和焊接技术。
How to repair broken LCD Screen
Amigos,
LCD screen of my iPhone(A1203 - 1st Gen) is damaged and I need a new one.
I can't locate this info on ifixit.com. Any pointers?
cheers,
Rocky
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
Here's how to fix it: iPhone 1st Generation Display Assembly Replacement
The part is not cheap, I'd do a lot of searching for prices before trying to fix it: http://www.idemigods.com/iPhone_1st_Gen_...
这个答案有帮助吗?
得分 2
1条评论:
http://www.rapidrepair.com/shop/4120-lcd... little cheaper and the least expensive on ebay at http://cgi.ebay.com/iPhone-1st-Gen-2G-LC... so it pays off to shop around :) good luck
完成的
添加一条评论
I've done this repair and it's a lot of work. You have to open the iPhone from the back to replace it. While you can buy the whole display assembly I did it with just purchasing the touch digitizer. It's a little more difficult but will save you $40. Shop around on eBay for the touch screen. Don't buy from China on this one. Read through the step by step on how to remove the display assembly and then check out youtube videos on how to separate the touch digitizer from the main display assembly. You're gonna need a hair dryer and one of the plastic pry tools. You can do it. I did that as the first thing I'd ever done on an iPhone. Take it slow when disassembling don't rush things. If something isn't coming easy don't pull harder. I did and tore a ribbon cable. Best of luck!
这个答案有帮助吗?
得分 2
添加一条评论
if it still works it not the lcd its the frunt plate
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rakesh 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 9,368
