跳转到主内容
A tablet released in September of 2015 by Amazon featuring a 7 inch multi-touch screen display. Model Number: SV98LN
50 个问题 查看全部
Black Tape Torn on Digitizer - Amazon Fire 7" 2015 Edition
Attempting to replace the motherboard on an Amazon Fire 7" 2015 model. I did not remove the digitizer before removing the motherboard (as instructions say I should do). I tore the black tape in order to release the motherboard. Am I now going to have to replace the digitizer? Or is everything ok,
You can see the digitizer is still attached to the motherboard. You can also see the black tape that was torn holding it.
Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@terdallaujar not sure which black tape you tore. Post some images of your damage with your question so we can see what you see. Use this guide 在已经存在的问题里加入图片 for that. For as long as you did not tear the ribbon cable you should be ok, but we need to see the damage to make that determination.
这个答案有帮助吗?
得分 0
1条评论:
Thank you...I should have done this to start with!
完成的
添加一条评论
添加你的答案
Kensey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 11
总计 91
