跳转到主内容
加入维修社区 - 创建账户
Repair information for LG dryers.
dryer won't power on
I have a LG electric dryer that won't power on but the interior lights work fine. I've have the thermal fuse and high limit,they were both good, I've also had the door switch and start switch checked,they too were fine. Has anyone had this same problem that could maybe help me out? I would hate to go purchase something that cost alot of money and it not be it. Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
5条评论
@billiejean39 what exact model is your dryer?
完成的
DLE2301R,I've looked everywhere on the internet to try n figure this out.
完成的
Yes it's a new plug and all was tested,and was fine. The only thing that we have tested n it not register was the thermostat assembly. Can this be bad without the thermal fuse or any of the other thermostats?
Thanks,
Billie Jean
完成的
@billiejean39 did you figure this problem out? I have the same model with the exact problem. Interior light comes on, but power button does nothing.
完成的
Any solutions yet? I have same dryer, same problem
完成的
添加一条评论
2个答案
已选择的解决方案
Most dryer run on 220 volts. This means in the USA that it is getting two 110 volt lines. Yours sound like it is only getting one 110. First throw the main breaker switch. That failing, test the wall plug and see if both legs are hot. Next use your multimeter to check the continuity of both lines going into the machine.
这个答案有帮助吗?
得分 1
添加一条评论
If it's a fairy new machine, there might be a diagnosis routine you could run. That might give you a code leading to the problem. Also hidden somewhere in the machine is a paper intended for a service person to help troubleshoot service.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Billie Jean Trowbridge 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 22
总计 3,827
