I need help please
hey im new here i have a sony bravia smart tv recently when i play my xbox one i power cycles my tv ....at weird times it should not turn my tv off and on when i play ,,,at all please help....thanks in advance
there is a feature that allows you to control your TV with the console.
http://www.ign.com/wikis/xbox-one/How_to...
This may be acting up. Try turning it off. If it still happens, it is either the TV, or the outlet.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 147
@luckylastone what exact model is your TV? Does it work with other input sources correctly?
由 oldturkey03 完成的
kdl-40w600b And thanks in advance.
由 luckylastone 完成的
@luckylastone Does it work with other input sources correctly? This willdetermine if this is a TV issue or an input issue.
由 oldturkey03 完成的
it seems to be working now since i unplugged my usb drive it dont do it kinda of weird???
由 luckylastone 完成的
Well, Sony TVs are programmed to look for firmware updates on the USB stick. Maybe there's something on there?
由 S W 完成的
