跳转到主内容
加入维修社区 - 创建账户
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
Searching for Transistor chips
Hello Guys.
I was able to change my CPU on this board but one stupid thing was happen:
I cant lift up the CPU with my mini Vakuum Sucker.
So there fell apart some pieces and now i need to replace the (TSP)51619 which controlls the Power of the DDR3L Memory. but byside of this are some tiny black
"Transistors"?
And there is no Water on the Board. it is only Pattex Glue to save the other componets from falling appart.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Klaus Iwik these components are not transistors. Those are all resistors.
Reference designator R7611 is a 35.7K ohm 1/20W 1% resistor in a 201 package
Reference designator R7614 is a 14.7K ohm 1/20W 1% resistor in a 201 package
Reference designator R7613 is a 47.5K ohm 1/20W 1% resistor in a 201 package
Reference designator R7613 is a 100 ohm 1/20W 5% resistor in a 201 package
这个答案有帮助吗?
得分 1
3条评论:
Very nice =)
Now i need to find a reseller of these.
完成的
@luckylastone depends on where you are located. I get mine from Mouser.com Digikey.com as well as multiple other common sources. Just checked Mouser and they do carry all of them. Careful so, shipping is expensive ;-)
完成的
@klausiwik I've bought from this place before: https://www.flywing-tech.com/, it's good quality.
完成的
添加一条评论
replace the logic board and the path CPU on the new one
这个答案有帮助吗?
得分 0
1条评论:
I just byed a old damaged board with Parts on it which i needed for 22Bucks =)
Thanks for this great idea!
完成的
添加一条评论
Never finished this board because I found a used one for 200bucks that is now working in my Book =)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Klaus Iwik 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 31
总计 418
