Power On No display
Its Power on but gives display sometimes and sometimes not give display
Hi,
Connect an external monitor and check if it shows a display OK.
Also when the laptop screen shows no display, use a torch and shine it at an angle close to the screen and check if you can detect a display at all. It will be very faint so perhaps it will be easier if you try this in a darkened room
这个答案有帮助吗?
try to open it up and disconnect the screen then clean the screen connectors with alcohol assembleitup and retry
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 25
总计 1,048
1条评论
maybe a loose cable
由 daniel 完成的
