跳转到主内容
關於自行維修iPhone所需的任何一切,從最新的iPhone15產品線,一路追溯到2007年所發布的初代iPhone。iFixit有著每一台iPhone維修指南、拆解資訊,並且完全免費,還有全宇宙最好的更換配件、工具、技巧!
36478 个问题 查看全部
What glue do you use for glass only replacement
I've been replacing screens for awhile now and generated a ton of broken screens, I recently started removing the broken glass from the lcds.
Just worndering a few things.
1) What is the best glue to use to glue a glass back onto the LCD.
2) Where do you get said glue for the best price.
3) Where do you get your glass at?
4) Any tips or tricks when glueing the glass only back on the LCD?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
For tips and tricks, you should watch the LCD screen refurbished video on YouTube. For glue and glass, you should ask your phone repair parts vendor, also you can buy them in iFixit. Only replace glass need some equipments like OCA Laminating Machine, Bubble Remove Machine and others.
这个答案有帮助吗?
得分 3
添加一条评论
You normally use Loca glue + a UV light to set the glue.
https://www.ebay.com/itm/FLASHLIGHT-UV-L...
See this youtube tutorial.
https://www.youtube.com/watch?v=7hzCCsex...
这个答案有帮助吗?
得分 1
2条评论:
All reputable refurbishers are doing OCA. LOCA is fine for one-offs (although not really cost effective). If the OP wants to do iPhone glass-only repair professionally, as the question suggests, they should invest in the proper tools and consumables, as Mandy recommends.
完成的
OCA and LOCA are the same glue. "L" simply means its the liquid form. The solid form is expensive due to the equipment as you said for a machine that can remove bubbles vs a simple UV light.
完成的
添加一条评论
添加你的答案
Frost tech repairs 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 10
总计 4,237
