跳转到主内容
加入维修社区 - 创建账户
Intel Desktop Board D945PSN 支持 2005 年发布的 LGA775 插孔。
Windows can't load correctly
HP Pavillion 23-HO56 All-in-One Desktop PC series,
My All-in-one PC fell from the table top and the glass screen is shattered, though the display is not affected. The main challenge now is that when powered, automatic repair runs and finally displays 'Windows couldn't load correctly' How can I fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Hi!
You should try creating a bootable Windows drive and running Diagnostics or "Startup Repair" from there.
Also, your Hard drive might have taken a hit which is why it could be malfunctioning. If you can't log in to Windows after you try a bootable drive that's most likely the cause and you will need a new drive.
这个答案有帮助吗?
得分 1
添加一条评论
No signal, Bata raha Hai
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ukan Anobo 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 25
总计 1,067
