跳转到主内容
Toy quadcopter with camera, controlled over Wifi by smartphone.
Is it possible to change the camera?
I wonder if it's possilbe to change any or both the cameras with a better quality camera ???
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
最有帮助的答案
I do think that this is a depends answer. Depends if you have the Drone, and can actually get the physical dimensions to replace it with cameras that are of comparable dimensions in order to not alter the flight characteristics of the Drone. Then it depends on the firmware/software that the drone uses, it may be specific for the cameras, and may not accept anything else. The only way to make sure that you can, is by doing it....let us know if you are going to so we can all learn something. Good Luck :-)
这个答案有帮助吗?
得分 1
添加一条评论
You have to buy the AR Drone Bottom Structure from parrot.com or Brookstone.com and goes for $59.99. I have yet to find a camera sold by it self.
这个答案有帮助吗?
得分 0
添加一条评论
Yes
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ali Ghasser 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 7,225
