跳转到主内容
The B6 and B7 versions of the Volkswagen Passat are front-engine large family cars produced by Volkswagen, a German automaker. The B6 line of the Passat was produced between 2005 and 2010, and the B7 line was produced between 2010 and 2015 as a facelift of the B6 line.
27 个问题 查看全部
What specifically does the yellow engine light mean?
The yellow engine light came on and my manual simply states to get it to a Volkswagen dealer. How serious is this...what are the possibilities? I live 1.5 hours from the nearest possible technician.
Update (12/03/2017)
Tysvm. I do not have a obd and cannot have one until the 11th(I'm very rural)... I'm wondering if it's safe to drive until then. I drive 80 mi a day for work.
Again, ty for that suggestion!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
What's your current mileage?
完成的
As @mayer asked, what's your current mileage? At what previous mileage did you get an oil change?
完成的
添加一条评论
1个答案
A lit engine light can mean many things. any chance you have an OBD-II reader?
https://www.walmart.com/ip/Fixd-72312029...
Note: my car knoledge is very limited so after this I'm not sure If I can help you.
这个答案有帮助吗?
得分 0
8条评论:
Dee, if you are in the United States, most auto parts stores will give you a read of your engine codes for free. The yellow engine light normally means oil change is due, but like @captainsnowball stated, it could mean something more dramatic.
完成的
@avanteguarde I thought they will only give the codes in MA because it is a state law. (Source: that thing on iFixit that pops up and says: "protect your right to repair" But, probably not the most informative source on that matter.) and also, isn't an oil change needed represented by a little oil applier thing? This thing: https://content.repairpalcdn.com/images/...
完成的
well then... It appears I am wrong. I made a good answer so I shouldn't get cocky.
完成的
@captainsnowball we are all here to help people. No worries. It's not a contest (at least not to me).
完成的
显示更多的3条评论
添加一条评论
添加你的答案
Dee Jarrard 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 256
