跳转到主内容
Guides and support for various television (TV) brands and styles.
9059 个问题 查看全部
Panasonic TH-L42ET60A TV has sound but no picture
TV has no picture, but has sound. When tv is turned on it has a faint light to it (appears to be LED backlight). Have taken rear panel off and connections look fine and has no blown fuses. When TV is turned on has solid green LED illumintaed. Any suggestions?
Update (12/03/2017)
Have looked at all boards and checked fuses and are ok, all connections seem fine and nothing seems to be overly hot when tv is turned on (see pictures)
Update (12/03/2017)
@oldturkey03
The fuse is intact, can you elaborate by what you mean about checking pins 1-5 on connector 1?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
6条评论
how ken problam this solution
完成的
Hi Team,
I have a Panasonic TV screen lights ON but, no sound and pictures
完成的
Hi @michaeltolasi
What is the model number of the TV?
Can you see the logo/menu screens at all?
完成的
Hello I am facing the same issue. TV is less then 1 year and the problem is coming frequent.
Suddenly picture goes off only sounds are playing. After switch of and on again it's running smoothly. Is it a problem? Or there is some special feature?
Thanks
Please help
falguni.roy1@gmail.com
完成的
Hi,
If the TV is less than 1 year old, it should be covered by the manufacturer's warranty.
Consult the warranty statement that should be with the documentation that came with the TV (or maybe it's in the User manual) as to what to do to make a claim for a manufacturer's warranty repair or replacement.
完成的
显示更多的1条评论
添加一条评论
3个答案
最有帮助的答案
@ethan1992 remove the back of your TV see and check the boards for any obvious damage. Leaking or domed caps are not uncommon. Check the fuses on the power board, as well as the fuses on the t-con board. You do want to post some pictures of all of your boards with your question. that way we can see what you see. Use this guide 在已经存在的问题里加入图片 for that. AS you've mentioned "has a faint light to it" probably your backlight working but not getting a signal.
Update (12/03/2017)
@ethan1992 there should be another board under the cover on the center bottom of your TV. Let's take a look at that one. Check connector 1 on the LED board to see how much voltage you get on pin 1-5. Check the power on the fuse on the same board as well. Check either side of it and let us know.
Update (12/03/2017)
@ethan1992 I was referring to the voltage on the LED driver board connector 1 "CNT1". Measure the voltage on those pins with your set on. Make sure that you do not touch other points with your probe and measure the voltage. You can use pins 6-10 as ground. Remember this is DC voltage so set your meter accordingly. Also measure the voltage on the fuse on the LED driver board and the T-con board let us know what you get.
这个答案有帮助吗?
得分 2
9条评论:
Checked pins, 1-5 had same DC voltage 23.45V and fuses checked out fine
完成的
@ethan1992 that sound like the right voltage for the LED driver board. Should now be a toss up between your T-con board and your mainboard. What voltage do you get on the fuse on the T-con board.
完成的
Appears to be 0.5VDC if I’m measuring correctly (between fuse on T-Con board and ground pins on LED driver board connector 1)
完成的
Try a different ground see what you get.
完成的
Every other labelled ground I can find produces same result
完成的
显示更多的4条评论
添加一条评论
Hi Ethan. When you turn the TV on, stand directly in front of it and try shining a flashlight directly at the surface of the LCD panel. Do you see the Panasonic logo or any source image when the TV boots up? It will be very faint. Sometimes putting the flashlight at an angle gives you a better view. If you are seeing an image, your backlight is problematic and your LCD and main driver board are working correctly. The problem can now be 1 of 3 items: The power supply, the LED power driver board (if its separate from main power supply) and the physical LED strips themselves.
这个答案有帮助吗?
得分 1
1条评论:
Thanks Anthony, I had a look with a flashlight but was unable to see any text or logos when turning on the tv, do you have any other suggestions?
完成的
添加一条评论
Hello, I know this is bringing back an old thread but I have the same exact problem. I have followed all the advice given, and my fuse is fine and pins 1-5 all ready 24V just like you. Did replacing the TCon board help? I'd prefer not to waste the money on it if I don't have to. Thank you!
这个答案有帮助吗?
得分 1
3条评论:
Yes, replaced the T-con board and it fixed the problem
完成的
Thank you for the advice. How much did you pay for yours and where did you find it?
完成的
I replaced the t-con board and still no luck. Is there anything I have to do to reset it maybe? Is there anything I should do? Or does anyone have a different suggestion on what could be wrong? Thank you.
完成的
添加一条评论
添加你的答案
Ethan 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 3
总计 22,424
