跳转到主内容
加入维修社区 - 创建账户
HP Officejet 6500 是一款彩色多功能一体机,发布于 2003 年。型号:CB815A#B1H。
What does the code 0x61011beb mean?
Printer code 0x61011beb
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
If all that software stuff doesn’t change your problem, there is a small plastic gear that likes to break in an armature inside the right side of the printer at the end of the silver rod that runs side to side through the whole printer. Once this happens, the print head can’t be properly positioned so you get the general error you posted. You can pop off the right side panel on the printer and the armature slides right off so you can access the gear. If it’s just cracked, you may be able to super glue it together and then reinstall everything and be good to go. If it’s destroyed, you’ll have to get a new gear somewhere. You might also try taking the pressing the broken pieces together into some clay or wax to make a mold which you can fill with super glue to make a new unbroken gear. Here’s a video showing a replacement being done on a 6500A Plus: https://www.youtube.com/watch?v=o8p9s7kI...
这个答案有帮助吗?
得分 1
添加一条评论
Could be a driver issue or the printer and cartridges aren't talking to each other.
Hit the link below for a fix I found:
http://www.personalcomputerfixes.com/how...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Evelyn King 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 34
总计 3,570
