跳转到主内容
加入维修社区 - 创建账户
D-Link DIR 600(也称为“Wireless N 150 Home Router”)是 D-Link 出售的一款无线路由器。它支持 802.11n Wi-Fi 标准,这意味着它的传输速度最高可达 150 Mbit/s。
How to Set up D-Link DIR 600
I have purchased new router D-Link DIR600 and I have already inserted internet cable in to router port but I have done all setting but still ip configuration problem showing.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
When you plug your computer into the cable modems Ethernet port are you able to connect to the internet? If you can, your problem is the default gateway setting in your D-Link is not set to the cable modems IP address.
We use the term 'Bad Gateway' as the direction of the next hop is not known.
Think of it this way... You're on the shore of a large lake, looking out you can't see the other shoreline on the other side so you don't know if its there or not. But, if your friend got into a boat and went half way where he can see both you and the distant shoreline he could relay your signal. Thats the problem here.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David Den 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 15
总计 796
