跳转到主内容
installed a new screen...no backlight! can I replace a backlight?
so, i've bought and installed the screen correctly...everything now i can see, as the old screen was damaged. BUT now i have no backlight and cannot use it in the dark. is there a way of buying a new backlight? or is it inbuilt with the screen?? please help. much appreciated
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I do believe that the 2nd generation iPod has a backlight coil on the logic board that has a tendency of corroding within the coil and thus shortening out. I do not of hand know which coil it is, but I know that is is difficult for DIY'er to replace the coil. SO I guess you would be looking at a logic board replacement. But I think the first thing you want to do is to dis assemble your iPod again and to make sure that all cables are connected right and tight. Also make sure that the cables are not fryed or broken, a good magnifier will help you with that. Clean the logic board and the connector with some isopropyl alcohol and do a visula inspection of the board. Reassemble the iPod and reset it and see what happens. Do pay close attention to any debris, corrosion etc. Good Luck to you and let us know if you are getting it accomplished.
iPod Nano 2nd Generation
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
kizzaks 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,516
