跳转到主内容
加入维修社区 - 创建账户
标准款Xbox 360的轻薄升级款,配有250GB硬盘和Wi-Fi功能。维修需要用到复杂且特殊的工具。
Red Ring New problem?
Hello
So i have sifted through multiple forums and have figured out it is a problem with a component in the xbox itself. Not say a bad powersupply. But the thing is I don't know what component it could be.
I have seen alot of people say its just the cpu and gpu overheating. So that would mean I would just have to repast all components with better heat pads. But I doubt that is the problem.
I know this problem is quite old which makes it even worse because of the many different fixes to all kinds of red ring of death problems. Because I have also found out that this isn't just some one solution fix. This red ring pops up from many different things that can go wrong with the xbox itself.
ANY HELP would be really appreciated.
Because Id rather not pay microsoft $80 plus shipping to have them ship it. When I can just get a used 360 s for 50-80.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
I would really not like to pay stupid Microsoft for something that is most likely the replacement of a single part.
完成的
添加一条评论
1个答案
TIME TO DEPART ON A QUEST TO DEFEAT THE DRAGON OF THE RED RING!
This my dear sir will be your gleaming sword: Xbox 360 Red Ring of Death Fix Kit
and this sir will be your Instructor: Xbox 360 Red Ring of Death Fix Kit
NOW GO SAVE THE REALMS OF XBOXLANDIA!
Fix kit for Xbox 360 consoles with the "Red Ring of Death" (RRoD) failure. Replace, reattach, and reclamp the heat sinks on your Xbox 360. Usually fixes a RRoD Xbox—also effective as a preventative measure. Kit includes: tube of Céramique 2 thermal compound (by Arctic Silver) screw and washer hardware pack thermal pads and heatsinks spudger Xbox 360 Opening Tool small flathead driver 1/4" driver handle with large flathead screwdriver bit and T8 and T10 Torx drivers.图片
产品
$29.99
这个答案有帮助吗?
得分 0
2条评论:
Not trying to make iFixit lose money, but those bolts and washers just flex the board more and the problem will just show up quicker. The whole point of the X-Clamps is to prevent flexing from damaging the board even more.
完成的
@ultratech yes a lot has changed since this all came out. We now know that no matter what "quick fix" we tried, The ultimate failure was based on the chip design and with out a proper reflow/reball or even chip replacement it would most likely fail again.
完成的
添加一条评论
添加你的答案
The Realist 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 442
