跳转到主内容
加入维修社区 - 创建账户
三星发布的首款 8 英寸安卓平板电脑。
Why does my tablet keep freezing?
Hi my tablet keeps freezing, I have tried a factory reset but that still hasn't helped. Freezing seems to occur randomly . Usually it's when I try to play a game but it's also froze when I'm doing nothing. Once the tablet is froze I have to hold the power button down to get it to restart and it occasionally hangs on the Samsung logo, which requires me to hold power button again and again until it decides to boot . My battery is pretty poor and the tablet spends most of its life on charge. Is it possible this is a battery issue or something else?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
7条评论:
its not a battery issue I would recommend to get it checked somewhere
完成的
Not sure what else it could be other than the battery, I've done a hard reset so it's not the software,it's not water damaged or anything .anything else I could check?
完成的
Did you just factory reset your phone through Settings or flashed the ROM? If not, try it.
完成的
Just factory reset. I will try flashing today
完成的
So I have flashed stock firmware and still freezing, I have noticed that it only really freezes after the tablet has been charging. Sounds like maybe the tablet is overheating while charging maybe? Any ideas?
完成的
显示更多的2条评论
添加一条评论
1个答案
Try freeing up space that should speed it up.
这个答案有帮助吗?
得分 0
2条评论:
I don't need it to speed up, just to stop freezing
完成的
Buy a SD card which will give you more hard drive space.
完成的
添加一条评论
添加你的答案
John 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 5,671
