跳转到主内容
加入维修社区 - 创建账户
奥迪 A4 是由德国汽车制造商奥迪股份公司生产的一款紧凑型行政轿车。2002-2005 款 A4 基于大众 B6 平台打造。
Oil inside the coil
What those it mean when there’s oil inside the coil
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Usually most of the leaks on the outside of the block or inside the cylinder combustion chambers are the result of a faulty valve cover gasket. When this happens, all you need to do is just replace the valve cover gasket. Installation of a new component is rather a straight forward process. To get the job done, follow the process:
  • Remove the valve cover from the head of the engine
  • Remove the old gasket
  • Keep the area clean with a rag
  • Spray some silicone spray where the gasket will be placed
  • Place on new gasket
  • Put the valve cover back, and torque valve cover bolts back to spec.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
EE408 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 15
总计 346
