跳转到主内容
The Viewsonic gTablet UPC300-2.2 is part of the first wave of Android tablets. It features a 1.3MP front-facing camera, 10.1" display screen, and runs Android 2.2 OS. There are a few common issues which can be readily fixed.
I can not enable the video mode
when the screen comes on a little display comes up in the top left corner that says video mode disabled. i have done the on volume button thing with no results
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Rob Vitale by this "done the on volume button thing " you mean a complete hard reset?
完成的
Ok. I hold the on button and hold the volume down button. It goes blank. Then it comes on for 1 second and on the screen it says that the UI launcher has stopped. Then freezes up. I did the same thing with volume up. It's not happening. All I wanted to do is clear the cookies and reset the app. preferences.
完成的
添加一条评论
1个答案
最有帮助的答案
Rob Vitale start with a hard reset. You will lose your files like pictures, music etc. when you do this.
You need to hold down the volume up button then press the power button for a few seconds until the tablet turns on, releasing power button, you should now be getting the recovery menu.
这个答案有帮助吗?
得分 1
1条评论:
after i did that. the screen came up with...magicware mismatch. critical failure, unable to start kernal. unrecoverable bootload error. whitch means is that it is stuck in a loop.
完成的
添加一条评论
添加你的答案
Rob Vitale 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 225
