跳转到主内容
加入维修社区 - 创建账户
Canon EOS Rebel T3 是 Canon 入门级 DSLR 相机系列 Rebel 系列的延续。它也被称为 EOS 1100D 和 EOS Kiss X50,配备了 12.2MP 图像传感器和 DIGIC 4 图像处理器。
LCD screen and backlight disassembly
I brought a new LCD screen without backlight on eBay for my Canon 1100d to replace the damaged screen on the camera.
Does anyone know if the backlight is suppose to come off the back of the LCD panel, it appears to be soldered in.
The backlight looks like a white plastic membrane and looks difficult to remove without damaging.
Thank you
Mark Bowles
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
In most cameras and smartphones the back light is integral to the display assembly, and if it's possible to separate them in order to replace one but not the other it would probably be classed as an expert repair.
That said, if you've got a broken LCD, you've nothing to loose by carefully trying to take it apart, in the process finding out how it fits together. With that knowledge you might be able to fit your old backlight to your new LCD. But if your old LCD is still just about serviceable you might not want to take the risk. On balance I'd be inclined to look at the eBay seller's returns policy, and if possible send it back and find another complete display from somewhere else.
这个答案有帮助吗?
得分 1
添加一条评论
In your camera, the back light CAN be removed from the old screen and used on the new screen only replacement this video shows how. Sorry this is late (I'm new here) but if you still need the info or someone else does, this will do it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Mark Bowles 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 34
总计 1,884
