跳转到主内容
加入维修社区 - 创建账户
2015 年 1 月发布。Android 智能手机。
No sim car Problem
When i am insert my sim in slot ,then it showing "No Sim Card".The slots are working fine.Before i am using reliance sim,after i am insert airtel sim then it showing no sim car .
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
sim1 and sim 2 shows NOT EXIST.. why its happening
由完成的 分享
sim 2 is not working
由完成的 分享
添加一条评论
2个答案
最有帮助的答案
I had a Mi(XiaoMi) Note pro in the past. Redmi and XiaoMi note share the same UI system. And this situation once happened on me. First check that if your XiaoMi UI is the formal UI or official Experienced UI.
If your UI system is an official Experienced UI, I suggest that you can send your phone to the Store to have a check
If you UI system is the formal one, press *#*#6484#*#* then you can check your sim card is good or not. If it shows that it doesn't works well than it's necessary to go to a Xiaomi Store to ask for help. The *#*#6484#*#*is an main simple way to check sim card works good or not.
I actually have some other ways to help, but I don't want to tell you all because that in China the workers in XiaoMi Store is helpful and I once had a try. BE CAREFUL when you're trying to fix some problems by yourself. Some of the good services are actually ONLY been developed very well in CHINA.
这个答案有帮助吗?
得分 1
2条评论:
i have this problem too, but sending it to the store is not an option, i need to fix this in my country
Do you know where can i find he logic board's diagrams?
I checked the simcard's sector on the board, nothing looks bad but need the diagram to be sure of what to check
Or if you know any other solution please help
由完成的 分享
mine is a Redmi 2 Pro
由完成的 分享
添加一条评论
check resistance between ground & the 6th lines of sim reader to be sure that they are connected ( GND / NC/DATA/ CLK/REST/VSIM) using Diode or Buzzer POSITION on Multimeter.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Prashant 7827 sharma 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 20
过去 30 天: 46
总计 5,968
