跳转到主内容
The 2014 edition of the Kindle, part of the 7th generation, includes a touchscreen and same form-factor as the Kindle Paperwhite, but lacks the backlight.
How can I easily fix the charging port?
My brother broke my tablet's charging port while he was unplugging it, and now it's really sensitive. I have to have the charger positioned exactly the right way, then I have to prop it up on something (like a pencil), and I have to check on it every 5 minutes to make sure it's still charging. And I found out that its actually losing battery power (last night it had 40%, but now it has 28%). It's really stressing me out and I need to fix it somehow. Is there a simple way to fix it without taking my tablet apart? I know that the problem isn't the charger, because I tried using a brand new one and it still doesn't work. I also can't afford a professional repairman or a new tablet. How can I fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
已选择的解决方案
@lolbit there really is no easy fix for it. To repair the charging port, you would have to disassemble your Kindle and remove the motherboard. Then you would have to un-solder the charging port and re-solder a new one. Look at these guides Kindle 7 to see what is involved and if you think you could manage the repair. If not then you can consider sending it to any of the numerous online places that perform this kind or repair.
这个答案有帮助吗?
得分 7
添加一条评论
What is a motherboard
这个答案有帮助吗?
得分 0
2条评论:
If you don't know what a motherboard is don't touch it yourself. send it to tech to get fixed or your gunna have major problems.😂
完成的
Where can I take !y Kindle in phx.??
完成的
添加一条评论
添加你的答案
A 12 year old 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 39
总计 20,483
