跳转到主内容
A tablet released in September of 2015 by Amazon featuring a 7 inch multi-touch screen display. Model Number: SV98LN
Where's the Internal Memory Chip on the Motherboard
Well my Kindle Fire finally took it's last breath today & I took it to a tech repair store to see if I can get the memory on it moved over to a new Kindle Fire.
They told me they could swap my old motherboard out & into the new Fire, but they also told me if it was a problem with the motherboard then it wouldn't even be worth it because it would cost me around $500 to find the SD card on the motherboard & to copy it over or something like that.
So I was wondering were the internal memory is on the motherboard so I can see if that would help them move over the information or not. And drive down the price because that's just insane.
Thank you for taking the time to read this & if you gave me an answer.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@d4rk1ight should be a Samsung Flash Memory IC under the EMI shield. If you remove those shields from your board and post some images of your board, we can identify the IC for you. Use this guide 在已经存在的问题里加入图片 to post some images with the shields removed.
这个答案有帮助吗?
得分 2
1条评论:
Sadly there is no swappable SD card here it's a soldered chip.
Maybe the cheaper way here is to just get another Amazon Fire of the same generation (used) thats working to try swapping out the logic board if you're up to it. Here's the IFIXIT guide: Amazon Fire 5th Generation Motherboard Replacement.
完成的
添加一条评论
添加你的答案
Christian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 30
总计 1,799
