跳转到主内容
PS3是索尼电脑娱乐推出的第三代家用电脑娱乐主机。2006年11月11日发布,取代上一代产品PS2。
Grinding noise when disk is inserted
My PS3 started making a grinding noise when a disk is inserted. It reads games just fine, and that's all I use the drive for.
I have replaced the spinning disk which stopped the noise, but it started up again.
I keep all my systems horizontal.
I forgot to say that it doesn't matter if I am playing a game or it's at the system menu, however it seems to happen more at the system menu and a disk is just sitting there.
Any other ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I had a crazy problem with this. I still have an old PS3 that plays PS1 & PS2 discs. whenever I played a PS2 I had a loud & crazy rattling noise. I googled it & read that the ps2 "blue" discs spin really fast, causing this noise. I came across this post & thought I would turn it vertically, then realized the 2nd controller we weren't using was on t floor vibrating consistently, causing the rattling noise. :/
完成的
添加一条评论
1个答案
已选择的解决方案
@ngw1031982 could be multiple issue from things like the gears, the disk drive motor as well as the tracking motor/drive. Use this guide PS3的蓝光驱动器更换 to get to the drive. Then you would have to disassemble it and see if you can locate the error. Ultimately it sounds like your drive is failing and may need to be replaced. Try to play your PS3 vertical and see if that changes the grinding noise.
这个答案有帮助吗?
得分 4
8条评论:
How should I verify if it's either the drive motor and/or tracking motor/drive?
Also, where is the drives model located? I can't seem to find it.
完成的
Since it is grinding check the gears for wear as well as the spindle bearings etc. A good visual inspection should reveal more.
完成的
At this point, I don't see anything wrong. All the gears have all there teeth, and they look in perfect condition.
As far as I can tell, everything is properly lubricated as well.
At this point, I would say it's most likely the drive motor. I guess I'm in the market for a new drive. Worst case a new PS3, which I will look for a slim as I hate the super slim.
完成的
Should i just bye a new console
I have the exact same problem i play games it starts to make weird grinding noises then freezes ive ran out of options
完成的
@lewiswindsor why? Just replace the drive and switch the board and you are ready to go again :-)
完成的
显示更多的3条评论
添加一条评论
添加你的答案
Nethaniel Weil 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 29
过去 30 天: 133
总计 28,162
