跳转到主内容
A laptop by Lenovo, commonly found in offices all over the world.
My laptop sound 5 beeps on start up
Hello,
My laptop is about 7 years old. Sometimes we I turn the laptop up it's sound 5 beeps and doesn't up. then, I turn the laptop off and try again until it's finally start up.
Importent - this problem happning for about 5 years so it's doesn't the age of the latop.
How can I solve it?
Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Hi!
According to this article, there might be problem with the main board...
What you could do other than replacing the board entirely is disabling the security chip in the BIOS and/ or swapping the CMOS battery.
这个答案有帮助吗?
得分 2
6条评论:
Yes, this could very well be a problem with the mobo (Motherboard) or the CMOS.
完成的
Thanks. How to disable the security?
If this is the problem why it's sometimes work and sometime dont?
完成的
@djeliran To enter the BIOS:
Turn off the computer.
Turn on the computer.
While the "To interrupt normal startup, press the blue ThinkVantage button" message is displayed at the lower- left area of the screen, press the F1 key. The BIOS Setup Utility menu will be displayed.
Then navigate to the security using the trackpad or the arrow keys and disable the security chip. If this does not work or if you fail to boot into Windows because of an error you were not getting before make sure to re-enable it and start looking for a CMOS battery replacement.
完成的
hi. I've had this problem for a while. Visiting the Lenovo site and updating the machine's drivers appears to have cured it. It took hours, but well worth the time and trouble.
完成的
my laptop is suffereing the same problem but with the black screen, the fan is on so is the led but it wont turn on
完成的
显示更多的1条评论
添加一条评论
Try the driver update on the Lenovo site.
这个答案有帮助吗?
得分 0
添加一条评论
even my laptop dose not have a battery eliran plesae note that i don't have a battery
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
eliran 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 48
总计 29,437
