跳转到主内容
加入维修社区 - 创建账户
一款专为日常使用而设计的 17 英寸触摸屏笔记本电脑。
Will not Connect to Network
As of a couple of days ago, my HP will only connect to WiFi in my home but not when the Ethernet cord is plugged in. I make sure the WiFi is off when trying to connect hardwired. There aren't any networks found. I have tried a system restore, removing the battery for 30 minutes but this did not resolve the issue.
I use my laptop for work and I cannot be connected wireless. I need to be hardwired. Does anyone know why my HP won't connect when hard-wired?
By the way, there is no damage to the Ethernet cord or the port.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Do you have another Ethernet device which is working with the same port & cable? Does the port have a link light? If it does is it blinking?
I would still try a different port on the hub and cable if you don't have a second device to verify. Sometimes the damage is not visible.
You may need to go into the Windows network settings to see if the Ethernet device drivers are loading
这个答案有帮助吗?
得分 1
4条评论:
Yes I also tried a different Ethernet cord and yes there is a light. I don't have the Ethernet cord in now to see if the light was blinking or not. I will follow up about this. The drivers showed as well.
由完成的
Check to see if you are pulling a valid IP address on the Ethernet adapter in the command prompt if you are using windows and make sure there isn't an ip manually assigned in tcp/ip properties
由完成的
Clever viruses alter network ip addresses on your laptop to go somewhere. Normal network connections should be 192.168.n. If a different ip address is seen, you've been hijacked but easily corrected with either a reboot or manually changing settings.
由完成的
@notbroken - What someone is using can be other address classes (or a V6 address vs a V4) and may not be a private address as they may not have a router which spans between a private and assigned address space as you are alluding too here.
As an example my ISP has me in 146.x.x.x via a VPN. You can check yours here: What is my IP Address
由完成的
添加一条评论
添加你的答案
MizzNeda 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 367
