跳转到主内容
加入维修社区 - 创建账户
第二代车型(底盘型号 L30)为北美市场专属版本,同样由 Nissan 加州设计中心在 Doug Wilson 的带领下设计,设计工作持续到 1994 年(1995 年设计定型)。
How do I install an ac compressor?
How how do I install an AC compressor on my 2000 Nissan Altima. I have never done it before so I need a step by step tutorial
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
there is special equipment needed to do an air conditioning compressor unit. the tools required will make it a job best left to a professional or at least someone with the tools . installing the pump is simply a matter of removing the bolets holding it on and putting the new one in also removing the to hoses and electrical connectors. thats the easy part once you put it together you have to purge the system of moisture by pumping out the air so you will need a vacuum pump . you will also need to replace the condenser. whenever you open a air conditioning system you need to replace this . Once youve purged the moisture you need to test to see that theres no leaks in the system and only then if theres no leaks will you be able to put the freon into the system . This is a very informative video
https://www.youtube.com/watch?v=95RdGLFI...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Monique l 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 2,218
