跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Tab 2 10.1 是一款 10.1 英寸的安卓平板电脑,属于 Samsung Galaxy Tab 系列的第二代产品。
Unfortunately Google Store Play has stopped
I keep receiving the message: "Unfortunately Google Store Play has stopped working". How do I fix that? Can I just remove that app and if yes, how do I download a version of that app?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 29
19条评论
Google has stoped
完成的
Unfortunately google play store stopped
完成的
Thanks for tip. Uninstalling updates worked wonders. Appreciate your help.
完成的
I need your help
完成的
What if I cant even open the app
完成的
显示更多的14条评论
添加一条评论
4个答案
已选择的解决方案
Hey Alain,
Unfortunately you can not uninstall Google play that easy, but luckily their isn't a need for that!
Google play may stop working due to;
Not enough memory on your device,
Your Date and time may be inaccurate.
I suggest checking both of these things, Another thing you can try doing is opening up your settings, applications, Application's Manager, Find Google Play. Their should be a 'delete cache' button. This deletes any miscellaneous properties and will not cause any harm. Once doing so go ahead and restart your phone and try it.
Hope this helps :)
Update (11/15/2017)
If that doesn't work, their is a clear data button, this removes your account info etc off Google play, But can be re-instated back on once you open up Google play again.
Now their is also a uninstall updates button, this restores the application back to its default factory settings. You could do this and go into the old version of Google and it should update itself.
Hope it helps!
这个答案有帮助吗?
得分 24
14条评论:
Hey Alain, Just coming back to check up, Just wanted to know if this worked, if not. How can I help?
完成的
Hi Brayden, It did work! I uninstalled all updates and defaulted to the factory setting. It works fine since then. Thanks for your help.
完成的
Awesome, Glad I could Help!
完成的
I had the same issue and uninstall updates did the charm. thanks much for the post.
完成的
I am unable to open any pages on my Galaxy Tablet i cannot get to settings or any other app,, any suggestions please
完成的
显示更多的9条评论
添加一条评论
Android comes with native Download Manager app that is used by Google Play Store and Google Play Services to download updates for apps as well as the Google Play itself. But some apps with download option modify that functionality by disabling Download Manager, which causes Google Play to stop.
这个答案有帮助吗?
得分 10
3条评论:
Deleting data from download and download manager worked for me , thank you
完成的
Yeah, gotta be careful with some apps and there permissions.
完成的
Thank you for your help i wouldn't have made it with out you your kindness was and patient was what I reedit thank yo bye
完成的
添加一条评论
Ok so I was haveing trouble but what I did was I disabled the app then enabled and it worked perfectly
这个答案有帮助吗?
得分 4
5条评论:
Yeah, some bugs happen, especially with older deices that aren't able to support the newer versions of the app.
完成的
What do you do if you can't disable the app?
完成的
Disabling and enabling again didn't help.
完成的
In my moto G3 mobile the window 'unfortunately the Google play services has stopped ' is not closing. The phone is not giving any response. How can I solve it.
完成的
GamerGeeks shows all MOD APK games and premium apps for Android devices. You can find and download all mods without viruses for more @thegamergeeks
完成的
添加一条评论
i think i have a huge problem i wish u could help me . ma old tab 2 (7.0 version ) doesnt work i dont know why the google play swont work (send a message :unfortunately , the google play store has been stopped) even the browser google or any app wont work :(((( i tried to default factory settings the tab and even that doesnt work .
any solution ????
thank you
这个答案有帮助吗?
得分 0
1条评论:
Hey @spartoxff Ensure the tablet is up to date and the time zone/region is correct.
I've had issues in the past where it was just down to the region set incorrectly.
Let me know how that goes.
完成的
添加一条评论
添加你的答案
Alain Tessier 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 42
总计 159,463
