跳转到主内容
加入维修社区 - 创建账户
索尼 DVD 播放器的维修和拆卸指南。
DVD door will not open
This model is RDR-VX515, VCR/DVD recorder combo. When I press the eject button I hear a noise as if the ejection process has begun. Then the tray does not open and I get the message "LOAD" as if the tray has opened and I have closed it. The next message is "NO DISC."
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
I would take the cover off, then plug it in and press the eject button to see whats preventing it from opening. Sometimes the mechanism that holds the DVD in place can get stuck, or something could be jammed in that whole mechanism chain ... you'll see what i'm talking about when you observe it with the cover off. You should not need to take anything apart ... just watch it when you try to eject and the cause of it should be obvious. Post back if you can't figure it out or you see something and don't know how to handle it.
这个答案有帮助吗?
得分 1
1条评论:
This is a Wonnie DVD player, the DVD door is opened by pressing on the door. There is no eject button.
由完成的
添加一条评论
添加你的答案
Glenn Stoops 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 22
总计 4,092
