跳转到主内容
加入维修社区 - 创建账户
Essential Phone 是 Essential 推出的第一代智能手机,发布于 2017 年 8 月。提供有月球黑、星光白、星光灰和海洋深蓝四种颜色。
SIM Card not recognized after drop
I dropped my phone last night, and now it thinks it doesn't have a sim card. How can I fix this? I've tried restarting it, but it cannot make calls, texts, or go online.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 14
7条评论
Actually, the ejectable sim tray had popped out part way and hadn't seated properly shut again. Problem solved!
由完成的
Dropped my phone and was super bummed . Came across this and it worked . You’re a life saver brotha , good thinking . Thanks G 🤙🏽
由完成的
I didn't get a sim card when I received my G33 BLU PHONE. SO WHAT IS THE DEAL???
由完成的
I have the phone but I don't have a SIMs card
由完成的
I had the same problem was able to fix with a twist. I used clear packing tape . 3 layers across top of sim card and part on card holder. sild in, bingo,, no circle with line through!!!
由完成的
显示更多的2条评论
添加一条评论
5个答案
已选择的解决方案
if the sim card is not reading, there is a high likelyhood something got damaged in the drop. either the sim reader itself, or, more likely, the logic circuit for the sim reader.
if you replace the sim tray, and it doesnt fix the issue, then the logic circuit is failing, and that would need to go.
这个答案有帮助吗?
得分 11
2条评论:
Insert Digicel sim card to a Voda android phone
由完成的
1150001700014884 किस नंबर लिंक है
由完成的
添加一条评论
最有帮助的答案
I solved this same issue, this might work for you too. Shut off your phone. Pop out the SIM card and place it on a thick piece of paper, use an exacto-knike to cut an outline of the SIM card on the paper. You can also draw an outline with a pen/pencil of the SIM and cut the outline. Try to be as precise as possible and dont exceed the outline, trim excess if needed. Then place the paper cutout in the SIM tray, place the SIM above the cutout on the SIM tray and pop it back in. Turn on your phone and you should get signal. If the SIM cant be popped back in, use a thinner paper, likewise, if this solution doesn’t work, test it out with a thicker paper/multiple layers of thin paper.
这个答案有帮助吗?
得分 38
47条评论:
Worked for me perfectly !! Many thanks !’
由完成的
Like which side should the paper be on the gold side or white side with numbers
由完成的
It works again thanks so much :)
由完成的
Wow. This actually worked. However, the way this is written implies you put the paper below the sim card in the tray. doing that you're blocking the contact points. the paper goes ABOVE the sim card, I assume this presses it down further. Thanks for this tip, though. Saved me a thousand bucks for now.
由完成的
This worked on my iPhone 13! Amazed! Paper goes on bottom of sim card on iPhone.
由完成的
显示更多的42条评论
添加一条评论
i just wiggle my sim card in and out and continue to turn my phone on and off
这个答案有帮助吗?
得分 2
1条评论:
This worked for me - brilliant
由完成的
添加一条评论
I ended up with two pieces of paper and it fixed the SIM issue.. But my issue returned when I tried to put it back in Otter case. Seems like there is some twisting of the phone that occurs when trying to put the case on. Solution might be to find a different case. Stayed tuned.
这个答案有帮助吗?
得分 1
添加一条评论
Haven’t taken it to a repair shop yet, but I have reset the phone, took the sim out, cleaned it, wiped the phone to factory settings, and it flashes "SOS only" and "No SIM".
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Emily 将永远感激不已
浏览统计数据:
过去 24 小时: 51
过去 7 天: 428
过去 30 天: 1,879
总计 170,773
