跳转到主内容
加入维修社区 - 创建账户
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示屏, 四核心 Intel Core i7处理器, 256 GB / 512 GB / 1 TB / 2TB 存储选项, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布。型号为 A1707。
Snap sound from hinge
When MacBook heats up and cools down I get a snap sound from the lower middle of the sceens hinge. I can also induce the sound by running finger along black strip that has MacBook Pro printed on it. Once it does it, it doesn't seem to repeat until the temperature changes again.
Has the MacBook not been assembled correctly? And if I live with the annoyance, will it eventually break down and kill the computer?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
2个答案
最有帮助的答案
I would bring it in to an Apple Store so they can either fix it or replace your system.
Remember you bought the system as working not having a defect. This is a defect which Apple also needs to know about as well so they can correct there building process.
这个答案有帮助吗?
得分 2
添加一条评论
I have this problem too!
I found this video as an example of the issue (I’m not the owner).
It always happen after few minutes of use. Sometimes the popping noise was so loud that I was able to feel it if was using the touchpad.
Don’t buy this computer if you plan to use it during meetings, public speaking or studying in silence. It’s really annoying.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kevin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 1,828
