跳转到主内容
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
iMac logic board LCD connector
Hello! Nearly a few days after replacing my iMac HDD with an SSD, after taking out SSD and putting it back i found it non-working. My first guessing was a bad LCD connector so i bought a new one, but it still didnt work. Plugging connector in the logic board nest felt bad, unlikely the same nest on the LCD, so i decided that the problem was in ligic board nest. After inspection i saw what you can see now at the picrure. What should i do with it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
@shardian you got the right connector and you can most certainly use a regular soldering iron. I stay away from hot air rework of the connectors. To solder the connector you'll use a technique called drag soldering. To prepare the board look at something like this. or the actual soldering observe the technique on here
It must only be the extreme professionals that perform boardlevel repairs on a daily basis, that have the practice to use a hot air rework station and Kapton tape for connectors.
这个答案有帮助吗?
得分 1
1条评论:
Thanks, after connector arrives ill try and update the post with the work done.
完成的
添加一条评论
最有帮助的答案
Doesn't look good ;-{
You'll need to find someone who can replace the connector (micro soldering). This job is tricky and you need the proper tools and skills to do it. The other direction is to replace the logic board.
Keep in mind the cost of this system and how much it's going to cost to fix. Sometimes its wiser to look at getting a new system (new or used).
这个答案有帮助吗?
得分 2
7条评论:
so i need to totally replace it with something like this?
http://i64.tinypic.com/158baz4.jpg
完成的
Yes I think that connector will do. This is not an easy replacement. I would strongly recommend you find someone who's done a few of these.
完成的
Thanks for advice, I'll try to. Won't the YouTube guides like this be helpful?
https://www.youtube.com/watch?v=Tn8dj8gJ...
完成的
Did you notice he has a hot air station? This is the tool you'll need and have had some practice using it. Even Doctors specialize ;-}
完成的
wouldnt it be possible o use a regular soldering-iron?
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Taras Vasylashko 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 650
