跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
706 个问题 查看全部
Joycon/procontroller Bluetooth chip/antenna inside switch?
Hi all,
Long story short none of my Joy cons / pro controller work any further away than a few inches from the switch.
I sent the switch in to Nintendo without this issue and a joycon issue, however it came back where nothing will work wireless more an a couple of inches away from the switch joycons or pro. Nintendo wouldn’t repair due to a crack on the power button.
Could someone tell me where this is located within the switch please? As I’m assuming someone opened it and something isn’t connected/missing.
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Thank you Alex :)
Will give it a go
完成的
hey, were you able to fix this?
完成的
I'm having this same issue however my Switch has never been repaired, dropped or damaged before. Did this work out for you?
完成的
@Will Wunsche Yes I fixed it, upon opening the ZIF connector as listed below had been disconnected.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi!
While I couldn't find a proper picture of the antenna placement on our teardown guide, there is a mention of antennae here at Step 10, perhaps you could tear it down until there and see if you can spot the antenna ZIF connectors.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Simon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 21
总计 2,266
