Joycon/procontroller Bluetooth chip/antenna inside switch?
Hi all,
Long story short none of my Joy cons / pro controller work any further away than a few inches from the switch.
I sent the switch in to Nintendo without this issue and a joycon issue, however it came back where nothing will work wireless more an a couple of inches away from the switch joycons or pro. Nintendo wouldn’t repair due to a crack on the power button.
Could someone tell me where this is located within the switch please? As I’m assuming someone opened it and something isn’t connected/missing.
Thanks
4条评论
Thank you Alex :)
Will give it a go
由 Simon 完成的
hey, were you able to fix this?
由 Atilla K 完成的
I'm having this same issue however my Switch has never been repaired, dropped or damaged before. Did this work out for you?
由 Will Wunsche 完成的
@Will Wunsche Yes I fixed it, upon opening the ZIF connector as listed below had been disconnected.
由 Simon 完成的
