跳转到主内容
加入维修社区 - 创建账户
LG V10 智能手机的后续机型,类似于 LG G5,于 2016 年 9 月 29 日发布。LG V20 可以通过型号 F800、H910、H918、H990 DS Dual、H990N Dual、H990T、LS997、US996 和 VS995 进行识别。它有钛金灰、粉色或银色版本,存储容量为 32/64 GB。
USB C port replacement
What is involved in replacing a damaged UCB-C port on the LG V20? Actually, I could ask a similar question for my iPhone 6S Lightning port. It's been pointed out that one advantage to "wireless" charging is the reduction of wear on power sockets. With daily use, that would be around 700 plug ins over a two year period, so wonder if this comes up often as an issue, and if so, how to replace a damaged power port.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
heres a video of the disassembly https://www.youtube.com/watch?v=5yC0ROV3.... to do the replacement you will need a hot air station, a soldering iron, flux and some leaded solder
这个答案有帮助吗?
得分 2
1条评论:
Thanks. I'll review the teardown you supplied.
由完成的 分享
添加一条评论
It can in fact be removed and replaced, but you definitely need a hot air rework station, in my opinion. I did find a YouTube video by a very talented person who was able to do it without a hot air rework station. The video is very well done, and I only wish I had his talent and steady hands.
https://www.youtube.com/watch?v=WgXMjRAU...
I took an old broken LG V20 logic board and was successfully able to remove the connector without damaging the board using my rework station. However, due to the heat, the connector that was removed did not survive. The board was fine, and no other SMD parts were moved or appeared damaged. I know that you can purchase the connector itself on Ebay. Be aware that it has both surface mount pins and 6 thru hole pins as well.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
William Vaughan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 5,606
