跳转到主内容
MacBook Pro powers on only when keyboard disconnected after water spil
My wife spilled water on her early 2011 Macbook Pro unibody. It was closed when the spill hit it.
It has been sitting for about a week now and there are no signs of water. Unfortunately it won't power on. After some tinkering under the hood and trying to no avail to get it to boot via the power pads, I discovered as soon as I flip the retaining flap of the keyboard cable it powers up immediately. It boots up all the way with trackpad functioning but no keyboard (naturally).
Is my only option an entire upper case replacement?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
I believe you accidentally did a spontaneous reboot by disconnecting the mag-safe then disconnecting the battery then replacing them. You can do it again just to check. The if it won't power down or restart from the power button, the keyboard has been shorted out and need to be replaced. If this is the case let us know and we can get you to the guide to do that.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
The keyboard could be shorting the power rails responsible for turning the laptop on or resetting the SMC (SMC_RESET_L). Replacing the keyboard will most likely solve this. Fortunately, you can replace just the keyboard, it is quite a tedious job though, as there are many small screws that hold the keyboard into the top case. There are quite a few guides for it on the internet :)
这个答案有帮助吗?
得分 2
1条评论:
Cant reset smc without keybord... Key bord is the culprit needs to be replaced...
完成的
添加一条评论
You probably have a bad trackpad and maybe keyboard. Try a new trackpad first and I bet your MacBook will work.
这个答案有帮助吗?
得分 1
1条评论:
The trackpad functions fine when it boots up with keyboard disconnected.
完成的
添加一条评论
添加你的答案
Jason 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 240
