跳转到主内容
加入维修社区 - 创建账户
Samsung NX Mini 是一款于 2014 年 3 月发布的微单数码相机。
Why does the sound not work
Ok so I have the Samsung nx mini and when I record sometimes the sound works and other times there’s a sound like staticky and then eventually it will just be completely silent it doesn’t happen all the time but if I was to record two videos changes are the sound would only work for one.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Is there any debris near the microphone hole of the camera? Sometimes tiny metal particles can collect on the top of a microphone and cause annoying background noise. Try vacuuming that tiny elongated hole on the top face of the camera and gingerly scratch the surface inside that hole with a toothpick at the same time. The toothpick can get any debris dislodged from the tiny microphone screen and the vacuum will suck it out of the microphone hole. Don't apply any pressure to the toothpick, just kind of drag it along the inside. Don't jab into the hole either. Dragging the toothpick should be enough to move any particles around and off the microphone screen.
Photo here:
https://www.dpreview.com/files/p/article...
这个答案有帮助吗?
得分 1
2条评论:
I’m definitely going to try this. I will get back to you but I have done this before. I didn’t vacuum the the hole just kinda got some gunk out, Hopefully this works I pray it doesn’t thank you and I will let you know.
由完成的
Good luck with it!
由完成的
添加一条评论
添加你的答案
Naomi Kay 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 28
总计 524
