跳转到主内容
The Nintendo GameCube Controller DOL-003. Released November 2001, compatible with Nintendo GameCube, Nintendo Wii, Nintendo Wii U, and Nintendo Switch. Repair for this device is straightforward and requires only common tools.
46 个问题 查看全部
Where do I find the positive and negative power sources on the board?
I am looking for power sources on the GameCube Controller motherboard. I need a positive and negative so I can connect some joystick LED's but I don't know where they are. Could anyone help me? I have two wires that I need to solder I just don't know where I need to solder them. Any help is appreciated.
Here's an image of LED Joysticks on PS4 controllers. It's the same concept but I want to do this with GameCube Controllers.
https://imgur.com/Kjmelo1 - Controller
https://imgur.com/ojsBInk - LED
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
@zad what you need to do is to post an image of your circuit board so we can point out where to solder to. It is one thing to look at what you want to do but you need to help us to help you. Use this guide 在已经存在的问题里加入图片 to do so.
Use your multimeter and trace where pin 1 terminates on the board. Pin 1 carries 5V and pins 2 and 5 are ground.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Zad 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 6
总计 868
