跳转到主内容
加入维修社区 - 创建账户
The first generation of the Chevrolet Equinox, a crossover SUV from Chevrolet based on General Motors' Theta platform.
car won't start, door locks , windows won't work, brand new battery
Had a new battery installed when my car died, still will not work. Mechanic says that a module has shorted out, but what one? windows, locks shifter will not engage at all. Headlights and dash lights work, Starter is good.
When trying to start just clicks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Have you checked the fuses?
完成的
添加一条评论
1个答案
最有帮助的答案
With the information you've given, unfortunately, it'd be hard to pinpoint a specific component causing the issue. Newer cars use complex computers/modules that can and will disable functions if certain signals are missing or parameters aren't met. The first thing that pops into my head is the "immobilizer system". Often times after a battery is replaced, the security system will disable the vehicle until the system is reset. Otherwise, the problem could be one of many different things. Sometimes an expensive diagnostic machine/scanner will be the only way to verify some of these issues. Could you elaborate on what happened when the vehicle died to begin with that prompted the battery replacement?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Tammy Gilbert 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 1,224
