跳转到主内容
HD action camera with touchscreen LCD, released October 5, 2014.
87 个问题 查看全部
camera not charging from usb port
usb port not working
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
simon gonzales check to see if there is debris in it. Also check for broken pins corrosion etc. If none of that applies you have to take it apart and see what is going on with it. Check to ensure it is still fully connected. Use these guides GoPro Hero4 Silver to work on it. Oh and you do want to get a new battery as well. If your battery is depleted it will no longer charge.
这个答案有帮助吗?
得分 1
添加一条评论
Not charging from port
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
simon gonzales 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 1,027
