How to change headlights bulb
How to change headlight bulb
@bexon59 open the front portion of the wheel liner. You should see a white cap with ridges and a tab, open that. Next there should be a silver connector socket with a lighting bolt symbol, pull that off. You should now see the back of the bulb and its clip. Squeeze the clip and pull it back to remove the bulb. This video also not the best, should help you with that.
这个答案有帮助吗?
IF you open the hood of your car there should be a big black screw (somtimes plastic) if you unscrew that you can pull you head light out and disconect the wires. Then you can take off the back cover to the headlight and change the bulb.
这个答案有帮助吗?
You can get to it from the inner fender, removing the front wheel well weather protector.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 35
总计 17,223
