跳转到主内容
How to replace asus ux360c touchscreen?
hii
i have a broken touch screen on my asus ux360c laptop.
i found a replacment touch screen
can anyone tell me if it is posible to replace only the touch screen?
are special tools/adhesive needed?
thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
Rather typing in here you must watch in YouTube to get an idea to replace the screen.
这个答案有帮助吗?
得分 -1
5条评论:
i search here and on youtube before posting , didnt find anything regarding this model
完成的
Ok you need size 00 Phillips screwdriver, 4mm hex bit, plastic triangle or card splunger or guitar pick would do to pull out the screen, heat gun to heat the digitizer/touch screen so that the adhesive will loosen up the screen and it can be pulled off. To put back you have 4mm adhesive strips to glue the screen. Hope it helps. You can search for Asus flipbook or look for a similar model procedure is mostly the same
完成的
@chris7up are you sure? There are no cable connection or anything else?
完成的
@chris7up At the risk of seeming insensitive, this is not a very informative answer. All you said was "go look it up", in your original post.
完成的
I got the same problem, does anybody find out how to replace it?
完成的
添加一条评论
添加你的答案
yuval 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,821
