跳转到主内容
加入维修社区 - 创建账户
Asus X200CA 笔记本电脑尺寸为 11.6 英寸,重 2.6 磅(约 1.18 kg)。它搭载 Intel® Core™ i3 3217U 处理器、Intel® ULV Pentium® 2117U 处理器或 Intel® Celeron® 1007U 处理器,配备 2 GB 或 4 GB 内存、320 GB 至 1 TB 存储空间、Windows 8 操作系统、高清摄像头,电池续航时间预计为 3 小时。
Keyboard is not responding?
Some of the keys do not type.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Fixing individual keys is not usually possible, but a complete new keyboard is not that expensive and quite easy to fit. Make sure you get one of the right nationality (US, UK etc as appropriate) and do a google search for Asus X200CA keyboard replacement for a guide. From a quick glance it looks like there are one or two screws on the bottom of the laptop that you have to remove, then there are a few tabs, probably along the top of the keyboard, that you have to release with a spatula or thin knife to allow the keyboard to be lifted out.
这个答案有帮助吗?
得分 1
添加一条评论
Keys are Stuck
There might be crumbs stuck inside your keyboard. Try holding your laptop upside down or at a 45 degree angle from being horizontal and give it a few good shakes that will dislodge anything stuck between your keys. Use a keyboard vacuum or a can of compressed air, these can help to remove any particles in between the keys interfering with its usability.
Loose Cable
The ribbon cable connected to the keyboard may have come loose. Fix this by reconnecting the cable.
Water Damage
If you spilled any liquids, especially soda that can get sticky when dried, apply some cleaning solution, such as rubbing alcohol or soapy water, to a dish towel and gently rub down the affected keys. You can also remove keys and wipe it from the inside.
If those methods are not applicable, try rebooting your computer. If none of these work, try replacing the keyboard.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Maricarmen Garcia 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 23
总计 760
