跳转到主内容
Model A1285 / 8 or 16 GB capacity
206 个问题 查看全部
问题已关闭
Clickwheel not working, even after replacement
Grabbed this cheap since the clickwheel wasn't working, figuring it would be simple to fix. Bought the replacement clickwheel circuit board/cable and installed. Still not working. Does this mean something is fried on the board, or is there still hope to make this work?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
i have had issues similar to that due to a faulty hold button, check on that and makes sure it works. Also make sure that all your connections are properly made and that your cables are seated well. good luck
这个答案有帮助吗?
得分 0
4条评论:
Don't think the hold switch is to blame. If I cycle the hold on and off, the display lights up, so it seems to be detecting that correctly.
完成的
Did a bit more dismantling, and it looks like the tape on the back of the click wheel gave way when I was reassembling, and probably damaged the clickwheel cable. So I guess we try again....
完成的
Aren't those itty bitty things just a bundle of joy to work on ;-) let us know how it is going. Good Luck
完成的
Got another new clickwheel and tested without putting it all back together. Still no response. So either the clickwheels I've gotten off ebay are defective, or the fault is in the main board.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 876
