跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for LED, LCD, HD and other Vizio TVs.
How to fix double image
How to fix double image on my vizio smart led tv?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
8条评论
Oldturkey I already edited my post by putting the video, Another description on my problem is when I let my vizio led tv turn on for 5 minutes the double image problem will gone or it became normal
完成的
It looks like it is in a some sort of a rhythm. Let's take a look at some of your boards.
完成的
I posted the picture
完成的
I gently applied pressure but nothing happens on the image
完成的
I gently applied pressure on the orange thin ribbon inserted in the panel but nothing happens on the image
完成的
显示更多的3条评论
添加一条评论
2个答案
已选择的解决方案
Redjude Cadornigara most double images are caused by a GATE TAB bond failure. For that, you will have to check the thin orange flat ribbon cables that enter your LCD panel. Now this is the part where we have to see what you see in order to try and help you. Post some images of what your screen shows with your question. That will allow us to see what you see. Use this guide 在已经存在的问题里加入图片 for that. Remove the back of your TV and post some really good pictures of all of your boards and see if you can reach the orange ribbon cables. Apply some gentle pressure on those and see if the image changes.
这个答案有帮助吗?
得分 3
添加一条评论
The new TV now a days have life span bet 3-5 years. depending how often you are watching or using the TV. If the life is more than 5 years, good for you. TV Panel as well as electronics boards were not designed to work in a longer years. For any problem in Smart LCD/LED TV like no picture but with sound, solarize picture, no power at all, the stanby lit but not turning on, try to visit my youtube channel DASOL PAN and locate my Playlist How to fix TV. I have some english youtube blogger there that I subscribed. Otherwise try to seacrh on Youtube the problem you have. You can try this one if the video still available:
https://www.youtube.com/watch?v=ejaRVrnD...
If you can understand Tagalog Language, try to watch my Youtube Playlist (How to fix TV?)
https://www.youtube.com/playlist?list=PL...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Redjude Cadornigara 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 20
过去 30 天: 74
总计 19,421
