跳转到主内容
加入维修社区 - 创建账户
PlayStation Vita(PSV)是PSP的后续机型,其具有更加强大的处理器与画面,添加了第二个类比摇杆。这款设备发售于2012年2月15日。
Problem with right analog stick
my right analog stick looked stuck in bottom right direction.While playing fifa first touch would always be to bottom right without me actually touching any buttons.
So i looked and guide to replace right analog stick.But since i have not yet ordered replacement part, i thought of just unplugging the cable as i was fine with it not working at all.But now after unplugging cable it is taking ball to top right.
So now i have a vita which has right analog stick unplugged but still while playing fifa first touch is to top right.
Now need to figure out exactly which part needs to be replaced to fix this.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
i followed till Step 8 and than directly step 18 of PlayStation Vita Right Joystick Replacement to unplug right stick.
完成的
添加一条评论
2个答案
最有帮助的答案
Ajay B you had it right from the beginning. Replace the analog stick first, then re-evaluate. It is a glorified potentiometer and most likely just failed. At this time is does not matter where the "first touch" leads to. Use this complete guide PlayStation Vita Right Joystick Replacement for the repair
这个答案有帮助吗?
得分 1
1条评论:
i don't have replacement part yet,So just want to play without right analog stick.So after unplugging right stick,it still acts the same. Shouldn't it just disable first touch (it is using right stick) with right stick unplugged ?
完成的
添加一条评论
Did you found out what was the problem?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ajay B 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 3,733
