Why did half my screen go dark?
why did half of my sanyo tv screen go dark? right half of screen went dark like a shadow over it. I can still see picture and everything else works.
这是一个好问题吗?
取消
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店Rod Skelly a complete loss of drive data for all RGB information to the right side of the screen. This is sometimes caused by the flat cable connecting the T-con board to the LCD panel coming loose as well as a bad T-con board. For anything more about that it will help if you do as @jayeff suggest. We'll need your exact model number and it will help if we can see what you see. Use the link provided by @jayeff
If this is an older LCD type TV, then it is possible that the backlight on that half has failed. Some of the older TV supplied light from each side. Please post the exact model number of the TV so we can confirm that this is the case or suggest other possibilities. Given the way most T-con boards work, I would not expect this type of symptom from a T-con failure.
Dan
声誉积分: 1
I am inquiring on model DP42D24 Sanyo. My left screen is going dark. How can I correct???
Hi Rod;
Please help…I am inquiring on Sanyo TV model DP42D24 Sanyo. My leftside of screen is going dark. How can I correct???
Thank you in advance….
Roy
过去的24小时: 14
过去的7天: 127
过去的30天: 597
总计 7,152
Hi.
What is the model number of your TV?
Which half are you talking about, top, bottom, left , right?
Try posting some images so that we can see what you can see.
Here's how. 在已经存在的问题里加入图片
由 jayeff
Top and sides of screen. Make of TV is philips
由 jintymccreadie
